Too lean mixture
Verfasst: 10. Mai 2020, 16:26
Hello fellow riders,
I've recently brought the carb to repair guy for maintenance check, as it had some problems with keeping rpm and seemed not worked properly. When I got it back and installed it into the bike, those previous problems seems to be solved, but now the bike runs rough on low rpm (shaky and wobbly), sometimes stalls when hot and drops revs slower than usual. For me it seems that the fuel/air mixture is incorrect as fuel ratio is too low. Is there any way to adjust the mixture while the carb is on bike? Please note, that I'm new at these kind of maintenance jobs as I prefer to rely on guys who specifies at these things, but in current situation I'm forced to do it myself. Thank you in advance
p.s. While installing the carb back I forgot where this hose needs to be connected
Cheers!!
Cheers!!
